Whites displayed blocky on Denon 2910
Discussion in 'Blu-ray & DVD Players & Recorders' started by AndyP123, Oct 20, 2005.
  1. AndyP123
    AndyP123
    Jan 26, 2005
    50
    +5
    I am running my 2910 through HDMI to a Samsung SP50 DLP and finding that anything white on a dvd is appearing very blocky, not sure of the technical term. Could this be macroblocking like other threads have discussed with this player.
    Is there a setting I can reduce or increase to eliminate this as it even effects skin tones if light is reflecting on faces, and sky is a big problem.
    Has anyone else experienced similar problems? Its annoying as darker scenes are looking amazing and I couldn't be happier.
    Andy
  2. Drew2
    Drew2
    Jan 12, 2005
    699
    Tsukuba, Japan
    +32
    Does your Samsung have DCDi? If so can you switch it off? It might just help.
  3. AndyP123
    AndyP123
    Jan 26, 2005
    50
    +5
    Drew
    My screen does have faroudja DCDi processing but I wouldn't have the first clue of how to switch this off. I have never seen this in the menus. The model is SP50L7H.
    I'll also post in the rear projection forum as I may get a better response.
    Do you or anyone else know?
    Andy
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    My display never showed up issues in bright or white scenes using a 2910. They always looked ok to me...
