White Walls, Grey Walls!
Discussion in 'Projectors, Screens & Video Processors' started by Rick1486, Feb 26, 2003.
  1. Rick1486
    Rick1486
    Feb 22, 2003
    549
    16
    Oxfordshire
    Hi gang.
    Looking at getting either the ptae300 or the hs10 as per my other thread, but here's another question for u gurus.
    Whilst browsing the threads the other night I saw one which made mention of grey screens and the fact that they're rare and expensive.
    Now personally - having seen pj's on both screens and walls, I prefer the piccie cast onto a wall (purely personal preference).
    What is the consensus of opinion ref. the best wall colour and why?
    Should I go White or should I go Grey?
    Look forward to some helpful advice.
    Rick
  2. ROGER THE LODGER
    ROGER THE LODGER
    Jan 11, 2001
    53
    +4
    Hi Rick
    A good start on this subject...... just do a search with the word 'icestorm'. loads of info comes up.
    Regards. Roger
  3. Rick1486
    Rick1486
    Feb 22, 2003
    549
    16
    Oxfordshire
    Thanks Roger - is that a search on this site or a search using GOOGLE or similar?
  4. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Nope, not Google. :lesson:
    Search here on the Forums for "icestorm" - its one of the grey colours in the Dulux range that you can get mixed for you in B&Q or similar places. There's a number after it "icestorm 5" "icestorm 6" - the number indicates that the grey colour is darker. Used by some to get better blacks, less perception of screendoor..:smashin:
    Sean G.
  5. John_N
    John_N
    If you try red walls you get really good colour saturation :)
    and black walls improves your black level a lot :laugh:
    Seriously though
    I tried white walls and grey walls and in the end bought a screen.
    The image on the screen is better. This is because the surface is perfectly uniform, whereas a wall is NOT:
    a) perfectly flat
    b) perfectly uniform.
    c) even in paint distribution
    d) perfectly smooth.
    A good test is if you use a 40IRE grey field on AVIA, you will actually see 'hot spotting' using a wall, which is where the middle of the grey field is actually a bit brighter than the edges.
    Just think - if it was that easy to paint a screen, then all the research and effort spent by companies on coating screens would be a bit of a waste of effort....
