White wall or white MDF screen?
Discussion in 'Projectors, Screens & Video Processors' started by godi32, Oct 15, 2001.
  1. godi32
    godi32
    This weekend I installed my Sony VPL-CX10 projector using the AlfaKhan ceiling method. I first projected the image on a light yellow wall but shortly after I saw the result started painting the wall using a white-grey extra matt paint. The result is great but I was wondering if I could improve the result by painting a MDF screen with the same paint. What would be the difference you think?
    My girlfiend doesn't want me to put black borders around the white screen. Is this a major setback in the image result or is the difference minimal?
    Thank you for the help!
    Dirk
    My home theater
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    the main diference i would have thought would be that there would be no blemishes . it would be a compleatly smooth surface (perfect for projecting on to)
    as for black borders . i think it makes a big diferense. it gives you a perfect edge to image containing it and giving you better perceved depth
  3. samwiley
    samwiley
    Mar 15, 2001
    84
    London
    Black borders make a HUGE difference to the whole cinema effect and perceived picture quality - so far the biggest (and cheapest) improvement that I've made!!
    Sam
  4. jrwood
    jrwood
    I cant beleive that there is no shop in Birmingham which sells velvet to blackout / mask my MDF screen
    That would make watching ultra large screen TV even more incredible :)
    James
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    James any good fabric shop will.
    Be prepared for some interesting looks though. Bloke buying material.
    Pound says the girl behind the counter thinks your making some sort of kinky outfit.
  6. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,783
    Cheshire
    +109
    James, Go to your local outdoor market and look for stalls selling fabric. Or find an Indian clothing shop selling Saree's, they often sell fabric too.
    Alternatively, I can supply black velvet at the bargain price of £30 per metre ;)
    [by the way, that was a joke]
    Regards
  7. jrwood
    jrwood
    After having quotes of £800 for general living room curtains that seems a bargain Chris ;)
    I'll checkout the market and see what small shops I can dig up!.
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Try John Lewis, they seem to sell most stuff like this.
  9. stuart-f
    stuart-f
    Aug 6, 2000
    45
    9
    Saint Paul-en-Foret, Var, France
    I'm lucky enough to have a dedicated cinema room and use a Dalite screen which has a narrow, 3" black border and it was mounted on a light wall. This was OK but after one particula trip to the cinema I realised that I needed to paint the wall behind the screen black. I used the darkest shade of Dulux Ice Storm (mixed at B&Q). This made a huge difference to the overall feel of the picture.
    Anyway after all that the point is black borders do make a difference and if you can't get the right material you could try painting a border, (remember to use matt finish).
