White vertical moving line on sky
Discussion in 'Sky Digital TV Forum' started by nictotten, Jul 30, 2004.
  1. nictotten
    nictotten
    Jul 28, 2004
    270
    +10
    I seem to have a problem on my sky channel. Theres two boxes in the house a normal sky box and i have a pace minibox. I have a 1cm white line that moves anticlockwise across the screen in 5 second intervals but this isnt on the normal sky box downstairs or on any of my terrestial channels. Any ideas what it is and how to fix it?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Does this line appear on both the scart and RF output of the minibox?
    What about if you connect the minibox to the LNB connection and the TV in the other room, same thing?
