White noise on Sky + problem
Pez942
I've done a quick search and found simliar problems with no definative answer.
First of all my set up is as follows
Sharp Aquos 42" lcd tv
Sky + (Pace box)
Sony G900 theatre stand.
My tv is connected via HDMI to the input HDMI on the G900.
My Sky + is connected via scart on ext 1 on the tv and via an optical cable from the pace box to the optical input to the G900.
Everything was working fine until I purchased my Harmony one remote yesterday. Now when rewinding or pausing there is constant white noise coming from my amp. When i change channels on sky there is also a brief bit of white noise before the channels sound kicks in. If i turn the background noise off in the sky guide there is constant white noise while in the EPG.
If i mute my amp and play the sound through my tv speakers then the problem disappears.
Hope i've explained that so it makes sense to someone.
Stevenage Neil
Are you saying that this problem only occurred after the use of a Harmony remote, (whatever that is)?
What happens if you go back to your original configuration?
Pez942
I had the same problem when going back to my original set up.
Not to worry now as I have sorted it. The good old turn everything off at the mains for a few minutes seems to have sorted out whatever the problem was.
Thanks for the reply though.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
