white line moving up screen ?
Discussion in 'Projectors, Screens & Video Processors' started by shabbyroad, Feb 4, 2001.
  1. shabbyroad
    shabbyroad
    Sony PAL VCR connected to Seleco 320Plus via my Marantz amp. All s-video connections (same symptom with plain composite video connection).
    This is most noticeable when a black image is on the screen (that is, with no tape playing or no TV signal). It is a ghosted white bar moving up the screen image - that's about the best way I can describe it.
    Suggestions on where to start troubleshooting ?
    visit Shabbyroad Records, Dublin, Ireland http://www.shabbyroad.com
  2. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,782
    Cheshire
    +109
    Thats a pretty good description of a "hum bar". This is where there is an electrical earthing problem somewhere in your system.
    Are there any electricians out there who can advise on a solution?
    Regards
    Chris Frost
    Regional Sales Manager-N.England & Scotland
    Owl Video Systems Ltd
    www.owl-video.co.uk
  3. shabbyroad
    shabbyroad
    you're spot on...I disconnected the co-ax from my sat dish/cabletv active splitter (on a different circuit to the home cinema) and it stopped (along with the other 'flickering' problem I mention in another post).
    Now....how can I reconnect my co-ax to the vcr without said ground/earth problem ?
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    Chris you beat me to it....
    Shabby you need to get hold of a thing called a ground breaker. It's an in-line device that de-couples the earth on the co-ax. This may eliminate the problem or at least help it substantially.
    They are usually available from high quality satellite/rf aerial installers. Or send me an email and I'll see if I can get hold of one.
    Channel plus do such a device but I'm not sure of the price. Your local hi-fi dealer should be able to call VEDA, the distributor, to get a cost for you.
    Gordon
    StereoStereo
    Intelligent Solutions for Intelligent Homes !
  5. shabbyroad
    shabbyroad
    MANY THANKS CHRIS AND GORDON !!
    I'll do a little digging around and see if anyone in Dublin has one that they can supply to me.
    -Peter
    >Shabby you need to get hold of a thing >called a ground breaker. It's an in-line >device that de-couples the earth on the co->ax. This may eliminate the problem or at >least help it substantially.
    >They are usually available from high >quality satellite/rf aerial installers. Or >send me an email and I'll see if I can get >hold of one.
    >Channel plus do such a device but I'm not >sure of the price. Your local hi-fi dealer >should be able to call VEDA, the >distributor, to get a cost for you.
