I’m looking for some white* wall mounted/mountable speakers to go in a kitchen (c. 6.1mx4.8m). (*At a pinch, I could spray speakers that aren’t the right colour.)
I’m not really looking to spend more than £500, £600 tops, including any mounting hardware, preferably (a lot) less. Second hand preferable, to help keep costs down (not time critical, so I can wait for the right things to come up).
The options seem to be:
(A) Flat wall speakers, e.g.
(B) Some small speakers (e.g. bookshelves like the PMC DB1 or even smaller) that could be mounted with brackets off the ceiling
(C) A 2.1 satellite/sub system (provided the sub is pretty small - ideally something which could be wall mounted. E.g.
Since this is going in a kitchen, they’ll be exposed to some steam / smoke / aerosolized fat etc, so ideally something that can cope with that.
Acoustically, the setup will be suboptimal - a very reflective room; unable to position the speakers correctly, etc. But this is to entertainment / listening whilst cooking, etc, rather than serious hi fi (I have a different space and setup for that. So it may well make sense to spend less ...
Sources will be: Amazon Echo Dot; bluetooth (probably via the Dot, unless the system has inbuild bluetooth), and phone audio (LG G6 and Sony Xperia II)
I am currently using PMC TB2 (or TB2+) powered by Flying Mole DAD M100 monoblocks, via a Cambridge Audio C500 preamp. Sadly the PMCs are too big have to go (well, get moved into another room). I can keep the amps, or I have a Marantz PM66 KI Sig I can use instead or - considerably less good - a Cambridge Audio A1 (the latter two options would take up less space and probably be more than fine for the job). I could always buy another (s/h) amp.
Ideas most welcome - many thanks in advance!
- Kef T101 £299
- Dali Oberon On-Wall Speakers 499
- Dali Opticon LCR MK2 On-Wall Speaker £599
- Bose 891 £499
- Polk Audio 265-RT £229
- Polk Audio Vanishing Series
- Monitor Audio IV140 Invisible Speaker £550
- Monitor Audio MASS 5.1 (Mist) £659
- APART AMBIENT SET W | 2X SATELLITE SPEAKERS + SUBWOOFER £509
