White Formika as a screen
Discussion in 'Projectors, Screens & Video Processors' started by vicbarry, Jan 20, 2004.
  1. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Hey all. I hope i have the correct spelling of this. I am about to purchase a Sony Hs20 and at the moment my budget does not include a screen. I am planning to use a 7x4 sheet of plain white Formika (the sort of wood that is used in alot of kitchen cupboards, indeed my mother has it in her kitchen). I have tried out my old Hitachi CPS220 off my mothers cupboards and the image was quite bright and suprisingly good.
    Does anybody else have experience with white formika. How do you think the HS20 would look on it.
    Cheers.
    Vic
    :clap:
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,201
    +3,039
    I don't think this is a great idea. The covering is likely yto not reflect light evenly resulting in colour shift and hot spotting.
    A cheap alternative that is likely to be MUCH better would be a piece of 12mm MDF from Homebase painted with matt white paint.
    Gordon
  3. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    Never thought of that Gordon. Thanks for that. Ill see how bad or good the formika is before i go for the MDF. But it sounds a far better alternative.
  4. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    I tend to agree with Gordon. Formica has a slightly glossy surface which is most deffinitely NOT what is required here.
    A piece of MDF and a tin of emulsion will cost less. I suggest you use a roller (rather than a brush) to do the painting - so as to get a more even finish.
  5. smartiepants
    smartiepants
    Jan 22, 2004
    219
    +9
    I to have tried white formica it tends to reflect light back (is this what you guys call hot spotting?)its good as a temp solution but i am looking to invest in a screen im a bit confused with so many types its for my H56 :)
  6. vicbarry
    vicbarry
    Oct 13, 2003
    457
    Cork
    +7
    .[​IMG]
    Went ahead and got my formika screen together for about €25. The image here is from taxi 3 on my hitachi cps220. Its a bit greenish not sure why.
    Previously i was only using a bedsheet :blush: but since i made the DIY screen i have noticed a better and brighter PQ from the hitachi. When my HS20 arrives on mon/tues next week ill post some pics. Cant wait
    [​IMG]
