White dot on image!
Discussion in 'Desktop & Laptop Computers Forum' started by MarTTy, Jul 19, 2002.
  1. MarTTy
    MarTTy
    Jun 10, 2002
    34
    Can someone help, I keep getting a white dot appearing on my Monitor and Panny AE100 when I run Power DVD, I am also using Powerstrip set at WIDE 480 (856x 480).
    It can't be a dead pixel as the Monitor shows the problem as well as my Panny. I can get rid of the dot by moving the vertical image using Vertical position on the panny. It's getting to me now as I want to have a clear image and the damn thing keeps staring at me!
    Martin
  2. Kramer
    Kramer
    On the bottom left hand corner?
    Like the mouse isn't fully off the screen, but it is?
    A quirk of Power DVD I'm afraid.
    I don't think it's ever been fixed by anyone, hopefully someone will prove me wrong :D
  3. GearHead
    GearHead
    Yesssss, somebody else has this problem too, its not just me.
    Bottom left hand corner, looks like the status bar is not being fully covered. Definitely not a pixel because I can change the aspect mode on the projector so that the image is a smaller rectangle in the middle of the screen and the white dot moves with the image.
    Currently I'm avoiding the problem by using a 4:3 aspect ratio resolution in windows (1280x960) and then telling my widescreen panel projector to zoom-in on the middle 16:9 portion of the image resulting in the top and bottom being cropped. This is just a workaround until I get the latest firmware installed in the projector that supports a native resolution of 1280x720 via DVI. When that happens I'm going to have the white-dot problem.
    One solution would be to run the bottom edge of the image into a black border.
    Allan
  4. jrwood
    jrwood
    Could always try clicking on the Windows status bar and choosing the option 'always on top? - NO' or 'hide task bar'... I personally have my windows status bar at the top of the screen anyway..
    Worth a try :)
  5. Kramer
    Kramer
    jrwood
    That doesn't work, unfortunately.
    I shift the pic downwards by pixel.
    That works :D
  6. jrwood
    jrwood
    Have you tried ZoomPlayer?, I doubt this exhibits the same problem??
  7. MarTTy
    MarTTy
    Jun 10, 2002
    34
    Looks like I'm not the only one eh! Does TheatreTek have this problem....if not I may go this route.
    Martin
