White border on TV
Discussion in 'Desktop & Laptop Computers Forum' started by Heinz, Aug 11, 2004.
  1. Heinz
    Heinz
    Hello
    Recently I created a VGA to Scart adapter to connect my HTPC to an old television (Panasonic). The TV only supports PAL. By using powerstrip I selected the custom resolution 720x528 50Hz interlaced.
    The image quality for movies is perfect, except for one thing: on the top of the screen the image is much brighter. It's just +/- 75 pixels from the top that go from black (under) to white (top of the screen).
    I already tried to alter the settings in Powerstrip (front & black porch and the vertical sync width), but that didn't make any difference.
    I hope any of you has a tip for this problem.
    Thanks!
    [edit:]
    I selected 720x528 instead of 720x576 or 720x568 because these resolutions have a lot of overscan (and also brighter white at the top of the screen)
