whistling Sky
Discussion in 'Sky Digital TV Forum' started by deezel, Jul 28, 2005.
  1. deezel
    deezel
    Oct 25, 2004
    322
    +7
    Turned on sky today and it seems I have a bird in my sky (box)
    Its a whistling sound.
    No probs with terrestial but all stations on sky are accompanied by a whistle
    Tried pushing all the cables home, and the whistle did flicker whilst I was doing this but the whistle persists.
    Its a new box, thomson
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Seems to be a common fault with Thomson boxes, you're the second one today ! Apparently a forced software download may fix it (remove power from the box, hold down "backup" button on front panel & keep held down whilst reapplying power, release button when you see the on-screen message). If this doesn't fix it, you'll need to get the box swapped out.
  3. deezel
    deezel
    Oct 25, 2004
    322
    +7
    yup, saw that other post.
    i got onto sky and he told me to switch off everything for 10 minutes.
    Sceptically, i tried this and low and behold the whistling has stopped......
    ... for now.
    If it re-occurs I'll try that fix you suggested, failing that i'll get sky out
  4. bignige
    bignige
    May 13, 2003
    666
    +27
    Third! I keep getting the whistling, unplugging usually does the trick.
  5. Daddy
    Daddy
    Oct 15, 2004
    40
    +3
    I posted last week with exactly the same problem from a Thomson box. The Sky engineer is coming out today to take a look but of course it's not doing it right now ! I'm hoping for a replacement but if not I'll try the software download thingy. I'm surprised the Sky tech helpline never suggested it ..?
    Andy
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    It's not likely to be a software thing. If your box isn't retaining its programming in memory, you have serious problems. It's more likely to be the power supply. Not a fault exactly, more of an annoyance. If a repetitive fault exists in a particular type of box, you can be sure the engineer knows about it, even if he doesn't let on.
  7. Daddy
    Daddy
    Oct 15, 2004
    40
    +3
    The sky engineer just came & he knew about the problem. It only affects Thomson boxes and according to him can be fixed with a software update but only if the box is whistling at the time you do the fix (presumably so you can prove it has worked ?).
    Anyway I now have a brand new Panasonic box. Not sure of the model but at least it's a decent brand and goes nicely with my Viera & E55 DVDR !
    Andy.
