whine on hard drive
Discussion in 'Computer Components' started by dennis, Jun 9, 2004.
  1. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    my 60gbt hard drive has developed a horrible high pitched whine,it's so bad it is hurting my ears,can someone recommend a replacement?price around £80.
    also what is a "sata"drive?.
    thanks
  2. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,221
    83
    Over the Hill & Far Away
    +139
    sata is the replacement connection for IDE.. you use a small cable similiar to a USB one to connect the HD to the motherboard.
    I use a samsung spinpoint 160GB.. it cost about £80..
    Matt
  3. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    thanks matt,where does it fit on the mobo?my pc is over 2 yrs old how do i make sure it's compatible
  4. Gillykid
    Gillykid
    Mar 4, 2004
    212
    Warwickshire
    Nah - SATA ports haven't been around that long, so i doubt you will be able to fit one. Best go for IDE
  5. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    thats what i thught,thanks i'll go for ide :smashin:
