Which XLR cable - Chord Cobra Plus or Chord Chameleon Plus?
James1
Hi everyone!
I have ordered a new hifi system:
- Audiolab 8200CDQ
- Audiolab 8200MB x2
- Spendor A5
I have also ordered Chord Rumour 2 speaker cable
I need an xlr interconnect to connect the CDQ to the MB mono blocs. It is between the Chord Cobra Plus and Chord Chameleon Plus. Which would best suit the system and is the better cable overall?
D.D.D.
If you have soldering skills I recommend you to build cable yourself - it is huge saving. I use in my setup DH-Labs / Silversonic cables, which compete with 2-3 times more expensive cables and if you go DIY way - then it will cost even less. I have some remains of AirMatrix cable and RCA and XLR connectors. I ordered from US a bit more than I need - If you interested - just post your "wanted" thread and I will reply. Sure, Airmatrix DIY stuff will cost as Chamelion Plus ready cable, but will be 2-3 steps up.
Some info you can find here
http://www.silversonic.com/docs/products/AirMatrix.html
(also replied to your thread in other location - Hi-Fi amps?)
