Which XBOX mod to get, and where to get a premodded box?
Discussion in 'Xbox Forums' started by t-force, Apr 13, 2005.
  1. t-force
    t-force
    May 2, 2001
    1,852
    Southampton, UK
    +143
    Well,
    The lure of Jade Empire seems to be proving too strong for me, so I may have to relent and buy an XBOX. I definitely want to take advantage of Hi-Def though, so a modded box is a bit of a must.
    However, there seem to be so many different mods out there, and I really can't determine what the real differences between them are. Also, I really don't fancy doing the job myself, so getting a pre-modded console would be preferable (with a larger hard drive if poss).
    Can anyone tell me what makes one mod better than another, and where are the best/most inexpensive places to buy premodded consoles?
    Thanks,
    Toby
