Which XBox mod chip?
Discussion in 'Xbox Forums' started by DazJWood, Nov 25, 2003.
  1. DazJWood
    DazJWood
    Jun 13, 2002
    176
    19
    Coventry
    Hiya,
    I have now had an XBox for a couple of months and am thinking of getting it chipped.
    Which mod chip is best?
    I think the most popular seems to be this Executor Chip, but I hear that the XBit chip is also gaining in popularity and is supposed to have extra features? Has anyone got any opinions on this.
    Also, where is the best supplier of these chips? I do not need a place that installs them as I will do this myself.
    Also, do these chips all have an external board that needs to be fitted? I ask this as I was thinking of replacing my DVD player with the Xbox and did not particularly want a piece of PCB stuck to the front on the XBox.
    Thanks in advance and any further information on these mod chips would be very welcome.
    Daz
  2. Kramer
    Kramer
    The Executer Lite 2.2 seems good.
    Recommend Premodded.
  3. CatManDo
    CatManDo
    Nov 5, 2003
    1,787
    South Yorks
    +248
    someone told me there is a mod available for the XBOX now that updates the bios.......ie no 'chip' is required
    anyone heard of this?
  4. holtehero
    holtehero
    Sep 10, 2002
    2,820
    Cambridge
    +1,741
    yes, my mate has just had one of xbox's 'Xploited' as it is known for about £35
    I believe you have to do some disk swapping with a CD for this non chip mod to work though once it is installed
    Good option if you don't want a chip fitting, but this mod still uses the slayer dashboard installed on the HD, so will invalidate the warranty just the same
  5. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
  6. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    wait for the new xecutor 2.3 to arrive - thats suppose to run on everything. i personally have the 2.2lite and its pretty much perfect tbh:)
  7. rahulkohli
    rahulkohli
    ^^^ when is the x-ecuter 3 coming out. im prob gonna buy a modded x box before x mas and am doing a bit of research on it now.
    at premodded they have
    Chameleon 1.3 Modified XBOX £175.00
    DMS X-BIT Modified XBOX £185.00
    X-Ecuter 2.2 Lite Modified XBOX £175
    anyone have any advice on what i should look for or what i should get. cheers
  8. nealgs
    nealgs
    Just had an email thru from http://www.mrmodchips.com saying that xecuter v2.3 lite is now instock with shipping from 28/11
    regards
    Gary
  9. rahulkohli
    rahulkohli
    ^^^cheers. what is the difference between the x bit and the x-ecuter. aprt from the £10 price difference.
  10. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    sweet :cool:
    thanks for the heads up Gary :smashin:
    much appreciated
    now all i'll have to do is buy my xbox! ;) lol :D
    cheers
    monsieurblack
  11. nealgs
    nealgs
    glad to be of assistance :)
    Am looking at Xbox myself - keep wondering into game to see what they have, suprised i've not yet been chucked out for loitering:rotfl:
    Not sure to go for modded Xbox or normal one then mod it myself at a later date.
    Anyone done a DIY mod (soldering etc), how easy was it?
    regards
    Gary
  12. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    lol! :rotfl:
    check out the thread i started best xbox AND gamecube deals around? for info on some great deals as not all the best are at game [looks like currently its whsmith on their 10% off evening...]
    unfortunately i have no previous experience on modding an xbox [or any console for that matter :blush:] but when i went to my friends in the states [not too sure if their versions are any different? :confused:] he showed me how he did his and took it all apart in front of me and it does look reasonably simple, i know i'll be very nervous doing it but think i'll have a crack myself :cool:
    just need a really thin soldering iron now ;) lol
    xecuter v2.3 all the way
    monsieurblack
  13. nealgs
    nealgs
    hehe.
    Steady hand needed also. I remember doing a memory upgrade on my Acorn Archimedes A310, went from 1MB to 4MB, which required removal of memory controller chips, etc and soldering a daughter card to main mobo, then replacing memory controller and 4*256KB roms.
    Was really cr&pping myself as this system had just cost me £1200 :eek: (this was in 1987-1988). But the mod worked, I was so relieved :D
    So the soldering shouldn't be to difficult for me (hopefully).
    Will have to checkout WHSmiths next Thursday, is it evening only then? 5pm onwards or something??
    cheers
    Gary
  14. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    ah ha
    good question :blush: :eek: its probably all day but thats just a guess :blush: i most likely put eve as that would be the only time i'd be able to make [after work] thinking of myself! lol
    i agree with the steady hand tho! a 'must have' 'feature' :D
    congrats with the 'ol upgrade :rotfl: that acorn must FLY! he he
    keep checking that thread out re: best deals as i'm looking all the time and wll add as n when i find
    *think* i may get a gamecube tonight for my bro's xmas prezzie...but we'll see...
    monsieurblack
  15. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Anyone in the cardiff area and wants theirs modded drop me a PM. Happy to help. Pop round for a coffee and I'll do it while you wait. No charge (chip price only) just happy to help.
  16. monsieurblack
    monsieurblack
    Oct 6, 2003
    550
    England
    +22
    WOW! :eek:
    man thats SO kind of you Messiah :smashin:
    i wish i lived near! :( suppose it'd be best if i got an xbox in the first place though :blush: it might help! lol :rolleyes:
    thats it! i've gone and done it...on the way back from work went in to gamestation a bought my brother a gamecube for xmas!!! [on the credit card mind, so i'll worry 'bout that after xmas. he he] got the mario kart deal with the five zelda games and resident evil and an extra controller [so he'll have two] and a memory card :cool: pretty good i thought for 99...
    luvvly jubbly
    lets hope he likes it now!
    monsieurblack
    p.s. looking more n more likely that i'll have to wait til i get myself an xbox now...perhaps after xmas sometime...???
  17. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi Kramer
    I will be moding my xbox real soon.
    The web site you recommended above doesn't seem to have
    any reviews or recommendations. Is there anyone else?
    Do you know anyone that has had their xbox modded by them?
    and can still go on xbox live?
    Ive read on the net that several xboxes have been banned from
    xbox live because they had been modded.
    Thanks for the link.
    Cheers,
    Shaz
  18. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi James
    You say your xecuter 2.2 lite is perfect but what made you go
    for it and not any other mod. Can you recommend any web site
    that can explain in "non-geek speak" what the differences are between the following mods:
    DMS X-BIT, X-Ecuter 2.2 Lite and X-Ecuter 2.2 Pro
    and why would I choose one over the other.
    Cheers,
    Shaz
  19. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    woo there thats a big question lol.
    i think the main difference between the 2.2lite and pro is that the lite comes pre-flashed with cromwell bios, while the pro comes without any bios. Also its possilbe to store 4x256k bioses on the pro, while only 2x512k is available on the lite (not exactly a problem though - i've only ever used one)
    TBH i choose the lite when the xbit wasnt around, and it just seems the easiest way to get it working. Ive heard the while the xbits can do just about everything you can imagine, they are a real dog to setup.
    there are many other little differences, far to many for me to remember, so the best advice i can give you is to head over to www.xbox-scene.com and take a look:)
  20. zcaps57
    zcaps57
    Hi, Shaz. :)
    Don't worry about getting banned from Live. Most of the mod chips (if not all) come with a on/off switch. So whenever you feel like playing on Live, you can 'switch off' mod chips, and the modded XBOX becomes just like 100% normal retail XBOX. :D
    As for the premodded.co.uk, although I don't have any experience with them, I've heard only good things about them. I think they're reliable.
    I do not have my XBOX modded yet, but I am considering it. :) BTW, my XBOX is US version.
    P.S. Shaz, get Live. I can't wait to see you on Live! :D
  21. Kramer
    Kramer
    Actually met the owner of Premodded over the weekend - nice chap & extremely helpful.
    As others have said, nothing but good things said about Premodded.
    He recommended the Xecuter 2.2 Lite which I went with & everything's OK (well, I hope so :) - see my other thread).
    Just get the Northern Monkey installer disc - as easy as pie :)
  22. dogma6
    dogma6
    Aug 20, 2003
    245
    28
    +26
    I'm also looking to chip mny xbox, has anyone tried the solderless chip?, I think it's called the Chamleon?
    I like the idea of buying this mod & being able to fit it myself without any soldering involved :cool:
    Any info would be gr8
  23. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hope this helps. it was useful to me.
    http://www.premodded.net/forum/viewtopic.php?t=28
  24. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hiya :)
    Thanks for your advice, I have become a lot wiser about xbox
    modifications etc.... a friend said to me "so what if it all goes wrong,
    just buy another xbox, there so cheap".. so he convinced me!!
    And abt xbox live... I can't wait! Im just waiting for Counter-Strike
    and Halo 2. ....sigh... if only i didn't need to goto work.
    I was on xbox live at a friends place ... I played Rainbow 6 pt 3
    and Moto GP, it was great fun.Except on MotoGP some "enlightened"
    ones were riding their bikes the other way
    at high speed. :) LOL
    Cya,
    Shaz
  25. thestorm
    thestorm
    Jul 13, 2000
    547
    East London, UK
    +30
    Hi James
    Thanks for your advice and helpful web link.
    Cheers,
    Shaz
  26. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Does anyone know if you have to disconnect the ethernet cable (i.e. break connection with broadband) if you boot with the chip on.
    Every time I boot with mod enabled I disconnect it from BB because some games try to boot straight into XBL. Do I need to do this (I'm not brave enough to just try it just in case :) )
  27. Kramer
    Kramer
    Go on, be brave :D
    Would like to know this too..........anyone?
  28. GrannySmith
    GrannySmith
    Sep 26, 2002
    280
    Pembrokeshire
    +8
    Messiah, you have a PM.
  29. sticker
    sticker
    Jan 14, 2003
    1,155
    36
    Sydney, Australia
    Messiah, top man, that's what I like about these forums, so many good people willing to help out :smashin:
    Regards
    John
  30. Messiah
    Messiah
    Apr 22, 2002
    7,616
    +338
    Well, I did it. So long as you boot to the EvoX menu you're fine. The downside though is if you intentionally or accidentaly choose MS Dashboard from the EvoX menu, and have the XBox set to automatically log in, then you'll be snookered as the chip will still be active (or at least the modified BIOS will be).
    As I was on saturday night :(
    Selected MS Dashboard by mistake and by the time I saw on screen what was happening it had logged in. Allowed me to carry on playing but when I wnet to log in last night I got the dreaded 'Modoified Software' message and my XBox had been banned.
    Luckily I had a few here that I had modded for people and one of them is never likley yo go on XBL so a quick mobo swap later and all was well (for mine anyway).
    Moral of the story. Don't leave anything to chance. If I had only one viewing room I would definietly have two Xboxes. One modded and one standard for XBL use. As it is I have the lounge and the HC room and there's no way I can justify four XBoxes.
    Shows how easily mistakes can happen as I even have 'push to make' switches so there is no way you can leave the chip on. It is off by default. I have no changed the settings to ensure it does not log in automatically and also set the EvoX settings to use a manual (incorrect) IP address so I always have to switch the settings before booting in. An extra level of safety.
    Be careful :)
