Which would be best
Discussion in 'Cables & Switches' started by jonallwright, Sep 9, 2005.
  1. jonallwright
    jonallwright
    Okay I have a toshiba 32wl56 and a philips dvp630 dvd.
    i connect 3 devices to the tv, sky on scart 1, dvd on scart 2 and xbox to the video input.
    the dvd has component out so i am looking at connecting it this way to the tv, the toshiba manual sugests connecting component to the mini d-sub 15 pin (svga) connector at the bottom of the set. i have after a lot of searching found the leads but they weigh in at 17 squid for the cheapest.
    a cheaper option would be component to scart.
    the million $ question is which would produce the best picture? :lease:
