Which wires?
Discussion in 'Blu-ray & DVD Players & Recorders' started by hywelm, Aug 19, 2004.
  1. hywelm
    hywelm
    Hi I was wondering if you could help me, i have been trying to put together the best system i can on a bit of a budget, my equipment is as follows:
    Sony MD deck
    Pure Digital DRX 701ES
    Denon 2802 amp
    Denon 2200 DVD player SACD/DVD-A compat
    Kef KHT 2005.2 speakers
    and may soon upgrade my TV to a Panasonic TX32PD30C but not sure if that is my best option for about the same money.
    My problem is what would be a good solution for my cable's and wire's as I don't really want to spend loads, but I also don't want to get rubbish that isn't going to complement my system. How can I do this without breaking the bank? I want to use the DVD player for CD's as well.
    also can I use a digital cable for my SACD and DVD-audio player and not have to buy 6 different cables
    THanks for your time and any help you can offer.
    HYwel MOrgan
  2. mevetts
    mevetts
    Oct 31, 2003
    439
    Probably get best response if this was posted in the cables forum.
    Mark.
  3. mevetts
    mevetts
    Oct 31, 2003
    439
    Apologies, looks like you have.
    Cheers,
    Mark.
