Which Wireless Broadband Modem???
Discussion in 'Networking & NAS' started by Complete Novice, Jun 6, 2005.
  1. Complete Novice
    Complete Novice
    Apr 19, 2005
    119
    19
    We have recently transferred from Dial Up to Broadband and, as we have two PC's, we want to be able to allow two people to use both at the same time, including being on the internet.
    Could anyone give me some advice as to what is the best thing to use in order to do this? We thought wireless would be best as, at present, the two PC's are in seperate rooms and I don't really want anymore wires in this house!!!
    As we are not flush at the moment the price is also a big issue. :thumbsup:
  2. MattTheBeanster
    MattTheBeanster
    Oct 23, 2003
    1,433
    Cornwall
    +100
    I have and recommend the Netgear DG834G. Amazon are selling it for £69.99. Not the fastest pc to pc but very reliable.
  3. tim k
    tim k
    i used to have a netgear router but it was really difficult to setup p2p downloading, as you need to change the ports. i now have the bt 1250 wireless router which i got from ebay for £40. bit of a bargain and works fine. it cuts out once in a while but i think thats cause im using aol on a bt modem.
  4. The Dude
    The Dude
    May 21, 2004
    6,283
    Beverley, East Yorkshire
    +2,602
    I'd recommend the Netgear too.. :smashin:
    I've had one myself, installed quite a few for mates, and never had a problem with one so far.
    They come with a removable antennae (?) too, which can be a godsend if you do have wireless problems, as a <£10 upgrade can save the day.
    It comes with a very secure firewall, nothing will get past unless you allow it, hence the initial config required to get P2P software working..
    From experience the 3com and Linksys versions of the same device are both spot on too, but overall I'd always go for the Netgear.
  5. Complete Novice
    Complete Novice
    Apr 19, 2005
    119
    19
    Could someone please tell me how these things work. Does someone have to be using the PC and connected to the internet which has the modem attached to it before the other PC with the signal box can be used or can they be used at different times?
  6. sput2001
    sput2001
    Jan 9, 2005
    425
    Manchester
    +18
    Nope. If you've set it up correctly then each PC will have independent access to the internet. Both PC's will be connected directly to the router/modem (either wired or wirelessly) so, as far as internet access is concerned, it won't really matter to one PC what the other is doing, or even if it's switched on.
  7. Skunkpipe
    Skunkpipe
    Just ordered myself a ZyXEL 662HW as I need something rock solid reliable and robust
    http://www.zyxel.co.uk/Products.32+B6JnR4X1p5WEVMcHJvZHVjdHNfcGkxW3Nob3dVaWRdPTg1JmNIYXNoPWI0NWJjMzdiYzM_.0.html
    it may be a bit OTT for home use - the 660HW is much cheaper and worth a look
    http://www.zyxel.co.uk/Products.32+B6JnR4X1p5WEVMcHJvZHVjdHNfcGkxW3Nob3dVaWRdPTcxJmNIYXNoPTc1NmU4YjAwNDE_.0.html
    Out of the more household names I'd go for Belkin or Buffalo as these are the only other manfacturers I having had grief with their wireless kit withl and what ever you do contemplate LinkSys (100% return rate with them) utter utter cr@p
  8. sput2001
    sput2001
    Jan 9, 2005
    425
    Manchester
    +18
    Both my router and wireless adaptor are LinkSys 54G's, and I've not had a second's trouble out of either of them.
  9. Da_Rude_Baboon
    Da_Rude_Baboon
    Jan 12, 2005
    492
    28
    +55
    Strange. Linksys are cisco's budget line and have always been great quality products with exemplary support from my expeirience so i'm sorry to hear you had problems.
    On the other hand my expierience with belkin wireless routers and a lot of other belkin products have been bad. Constant dropping of the line and poor customer support form their indian call center. The one exception being the N50 game controller which is superb.
  10. Complete Novice
    Complete Novice
    Apr 19, 2005
    119
    19
    So, now you have given me an idea of what to buy and how it all works, how do we know if one of our computers is USB 1 or USB 2 or doesn't it matter? :(
