which widescreen
Discussion in 'General TV Discussions Forum' started by psalliss, Jun 24, 2004.
  1. psalliss
    psalliss
    Aug 27, 2003
    615
    Heysham
    +12
    im looking to spend around about £1000 to £1200 for a new telly im looking at the leowe mimo or nemo as i prefer the looks, panasonic 32pd30 and the Toshiba 36ZP38, really like the look of the tosh but ive already got 5.1 so the extra speakers that come with it arent required. plus its a year old. please can some help suggest which of the above to go for as im confused. i need 3 scarts, would like at least 32 and 100 hz and am going to buying from empire direct as they have pay 2005 offer#
    cheers
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    PD30 but check returns policy in case you get a dodgy one!
  3. psalliss
    psalliss
    Aug 27, 2003
    615
    Heysham
    +12
    are there problems with the panasonic 32pd30, if so what are they. im also thinking that it may be worth going for the 36 panansonic, is there much of a difference between 32 and 36
