bren-escape
I posted a little while back about the tamron 17-35mm F2.8 DI as i have decided this is the idea zoom range for my budget (prob secondhand too). Is there much difference in the sharpness of this lens to the sigma of same distance (although i think the 'f' is different. i guess this mainly makes a difference in poor light/indoor use though? any others of this zoom to consider (can't stretch to a 17-40L).
Any advice welcome
Any advice welcome
