which way round are ur rears
Discussion in 'Home Cinema Speakers' started by shoalin kid, May 23, 2003.
  1. shoalin kid
    shoalin kid
    i am using M+K THX 750 and M+K tripole surrund 55s as rear backs .does any one use tripoles as side rears and normal rears at back? . which sounds better i have yet to try each way:suicide:
    dodge this
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,290
    United Kingdom
    +1,571
    Ideally the tripoles would be placed at the side and the direct radiating speakers at the back behind you. Whilst I have direct radiator speakers all around now, I was using dipoles at the sides before and they worked very well. :)
  3. shoalin kid
    shoalin kid
    cheers ill have to give it try
    mr.anderson.......suprised to c me
