Which way around does my fan go
Mr M
Hello,
I hope someone can give me some quick advice. I have a Samsung HT-UP30 DVD Home Cinema System and I have removed the small cooling fan (to clean it) which is located inside the unit, screwed to the rear of the case. I unfortunately did not make a note of which way around the fan should be reinstated :blush: ie should the fan a) draw cooler air from the room into the inside of the case to cool it down or b) draw hot air from inside the case, out to the room
Please help because I can't stand it much longer just using the speakers on my TV :thumbsdow
snakeyes30
In my experience fans that are placed near the rear of a system tend to blow hot air away from the system.
Does the system have any other fans inside? If so which way do they face?
Mr M
Thanks for the response. I have had a look inside and that is the only fan serving the unit.
RottenFox
well, on the fan somewhere there will be a mark,possibly an arrow, showing which way the airflow goes..most do.
Mr M
Thanks for that. I did already know about the directional arrow on the fan and mine has got an arrow marked on it. What I need to know though, given that I have already unscrewed and removed the fan from the back of the unit, didn't note the direction in which the fan pulls air and now need to reinstate it is - should the arrow point a) towards the inside of the unit ie drawing cooler air from the room into the inside of the case to cool it down or b) away from the Inside of the unit out to the room ie drawing hot air from inside the case, out to the room
RottenFox
its "b", the arrow should point out of the system, so effectively(i guess its at the back), it should point to the rear of the system, thus pulling hot air out of the unit.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
