Which wall mount for Acer AT3201W?
Discussion in 'Home Cinema Buying & Building' started by varez, Aug 30, 2005.
  1. varez
    varez
    Aug 2, 2005
    64
    Hello there,
    Does anyone know which wall mount fits the Acer AT3201W?
  2. varez
    varez
    Aug 2, 2005
    64
    c'mon - someone must have put this baby on the wall where it belongs :)
  3. Bigice
    Bigice
    I got one from ebay, bout £25 plus p&p will try and find the link.
    Pete
  4. varez
    varez
    Aug 2, 2005
    64
    bump
  5. Bigice
    Bigice
  6. varez
    varez
    Aug 2, 2005
    64
    Ah - thank you very much :smashin:
  7. pmwhelan
    pmwhelan
    Jan 6, 2005
    959
    Dublin 1, Ireland
    +46
    Anyone fitted one of these yet? Opinions?
    Thanks!
    p
  8. varez
    varez
    Aug 2, 2005
    64
    I found the producer's website, http://www.b-tech-int.com/Welcome.html and will order the BT7521 from them ones it's available again - only £12! I don't want the tilt (BT7522) as i want it as close as possible to the wall.
    I doubt anything so simple can be bad quality.
  9. stevej
    stevej
    May 21, 2003
    189
    +3
    I've fitted the BT7522 (the tilting one) and the only problem is with their locking allen bolts - in a word they are useless. I couldn't tighten the bolts enough to hold my screen (LG RZ26LZ50) in position. In the end I swapped them for regular bolts and used a ratchet and socket to tighten. It hasn't budged an inch since.
