which video/remote sender pls?
Discussion in 'Home Cinema Control & Remote Controls' started by sapkan, Oct 19, 2004.
  1. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    have a Philips sattelite box with scart and composite outputs and want to send video audio+remote control to a second room.
  2. sapkan
    sapkan
    Jul 8, 2004
    492
    +3
    anyone using the Lektropacks item?
  3. ssuellid
    ssuellid
    Oct 22, 2004
    207
    +7
    I use a digisender which is quite good. The picture quality is reasonable and quite watchable. At the time I bought mine it was the only box on the market that worked with all IR signals - some other boxes do not work with Sky+ or some cable stbs. The basic X1 or X2 models should be ideal.
    More details here: -
    http://www.digisender.net
    You can buy them at Argos - Argos have a pretty good returns policy so if you don't like the picture quality you can take it back. Good for a low risk trial.
