Which Video processor
Discussion in 'Projectors, Screens & Video Processors' started by Laingy, Aug 24, 2004.
  1. Laingy
    Laingy
    I have a Panasonic D4 plasma which takes a signal via component cables from an Arcan DV27. It also takes the sky signal via a JS box which converts the scart lead from the sky box to input into the plasma VGA socket.
    What I would like to do is put those sources through a scaler and have one output going to the plasma. Does anyone else have similar experiences of this and what was the solution, I am not sure if I would still need the JS box, and if not how would the sky signal be input to the scaler. Or do I keep the JS box and the scaler would accept a VGA input.
    regards
    Laingy
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    27,410
    The Borders
    +3,228
    Laingy
    The latest video processors from Lumagen and DVDO have recognised that here in the UK RGB+Composite Sync from SCART sources is quite common.
    If you look at the Lumagen VisionDVI, HDP and ProHDP along with the DVDO iScanHD you'll simply require a SCART to 4RCA cable between your Digibox and the Video processor.
    Best regards
    Joe
