Which Video light for Pan NV-GS400?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by wannabgeek, Apr 22, 2005.
  1. wannabgeek
    wannabgeek
    :) Hi i am looking to buy the GS400 but as all Camcorders are not too good in low light conditions i will need a Video light. Can anyone give me some tips and point me in the right direction as to which one to buy?
    PS i was looking at Panasonics version £60! :smashin:
  2. Brian110507
    Brian110507
  3. wannabgeek
    wannabgeek
    Hi Thanks for your info! I did try to get either one of those you mentioned but decided to go with Pannys own Video light VW-LDh3. It is a very small light but its very bright and only uses 3w of the Battery! I will soon give my opinion on how it performs !
    Cheers again! :)
