Which video card?
Discussion in 'Desktop & Laptop Computers Forum' started by Brogan, Jun 2, 2004.
  1. Brogan
    Brogan
    Oct 9, 2003
    7,582
    Cary, North Carolina
    +482
    I'm currently thinking of buying a Dell 20" TFT monitor: http://accessories.euro.dell.com/sn...e&refurbished=&c=uk&l=en&cs=ukdhs1&iCompatid=
    This is probably the first step towards upgrading my whole system which is about 4 years old and has an old NVidia GEForce 2 MX card and Win ME.
    Can anyone recommend a decentish video card which will suit the Dell monitor and also my Pioneer 504 plasma - hopefully with dual DVI outputs?
    It will need to be compatible with Win ME and an AMD motherboard until I build a new Intel XP system.
    I don't use the PC for games, only normal office applications so don't need anything too hefty.
    Thanks.
  2. andy572
    andy572
    Dec 4, 2002
    362
    Oop North
    Brogan, I think dual DVI is generally a feature of only the newest (i.e. expensive) cards. However, if you can find one, I believe Matrox make a G550 card with dual DVI. It'll be between £80 and £100... ish :smashin:
    Alternatively, if the VGA and DVI combination would be okay, there are nVidia and ATi options available for £30 and upwards.
    For an ATi card, look at the Radeon 9200 series. A particularly nice feature of these cards is that only a heatsink is used for cooling. For once, 'silent cooling' means just that! :cool:
    By the way, the equivalent Matrox cards are passively cooled, too :thumbsup:
    For nVidia, I think 5200 is the equivalent.
    Hope that helps :)
  3. Brogan
    Brogan
    Oct 9, 2003
    7,582
    +482
    Thanks Andy.
    I don't need dual DVI but just thought it might be handy for connecting to the monitor and plasma.
    But, as the plasma is connected to the 868 via HDMI then I guess I'm not really going to use it for that anyway.
    So, that being the case, I just need something which has DVI and VGA (for monitor and plasma respectively), can drive a 20" TFT and is a step up from my current GE Force MX.
    I guess I'll look at the Radeons as that seems to be the choice of most HTPC users.
    Can't believe they can be had for £30.
    Last time I put a system together, it was at least 5 times that for a decent card...
  4. NaTT
    NaTT
    May 27, 2003
    1,123
    Abbots Langley
    +77
    that'll be the hype over PCI-Express for you. loads of deals on standard AGP cards, 'cause they're about to bring out a technology that's meant to take a big leap forward for graphics to mobo interface.
