Which variant of Panny TH37 ??
Discussion in 'Plasma TVs Forum' started by welshwizard, Jun 15, 2005.
  1. welshwizard
    welshwizard
    got the go ahead from the Mrs, well how can she say no after i showed her a picy of the panny viera :clap:
    Anyway, i know what model of the Viera im after, but im slightly confused by the various variants of the TH37.
    Some are british models, euro models , some have inbuild freeview ( which i dont want ). Basically what letters after the TH37 should i go for ??
    All im after is connecting my DVD and Sky to the TV!!
    Can anyone help.
    mucho apprecatio
    mart
  2. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    If you're definitely after a Viera then the following codes apply:
    TH-37PA50, European standard definition model without integrated digital DVB tuner.
    TH-37PE50, UK specific standard definition model with integrated digital DVB tuner.
    TH-37PV500, UK specific high definition model with integrated digital DVB tuner.
    I've not seen European PV500 models listed by UK retailers but I guess some must be doing them. If you see an addition 'B' suffix e.g. TH-37PE50B then that denotes a UK specific model. The only other point to consider when viewing the Panasonic website is that they also make the distinction of how the TV is mounted, with the following suffixes: CAB - Floorstanding cabinet, PED - desktop pedestal, WAL - Wall mount.
    S.
  3. ash
    ash
    Jun 9, 2005
    11,221
    +395
    Whats the best price for the TH-37PV500 in the high street as I cant order online, jsut the normal desk stand.
  4. welshwizard
    welshwizard
    hi
    So whats the difference between the uk and euro models?
    and if you dont want the integrated freeview, is the euro model the only option
    cheers
    :thumbsup:
  5. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    that is the only difference - the freeview, so yes if you dont want freeview, euro is the only option.
  6. DJT75
    DJT75
    May 6, 2005
    10,556
    +3,489
    This is the cheapest I've found for High Street stores - http://www.hispek.com John Lewis should price match too..
    TH37PV500PED Plasma TV
    Includes pedestal stand and free DVD Recorder
    Price: 37" TH37PV500PED £2049.99
    TH37PV500WAL Plasma TV
    Includes wall bracket and free DVD Recorder
    Price: 37" TH37PV500WAL £1999.99
    TH37PV500CAB Plasma TV
    Includes cabinet and free DVD Recorder
    Price: 37" TH37PV500CAB £2299.99
  7. Steve_P
    Steve_P
    Jul 3, 2004
    1,338
    67
    +142
    Mainly the inclusion of the integrated freeview DVB tuner. The warranty situation will be different too as Panny UK will class European stock as grey imports. Probably, means Panny UK Customer Care will be more arsey with you if anything unfortunate happens.
    Pretty much.
    Instead of the Viera Plasma TV range you could always opt for the Panasonic plasma panel, TH37PW7. It's just a display panel monitor as opposed to a TV but you say you already have Sky & DVD. You'd need to buy an optional connection board for it.
    http://www.av-sales.com/plasma/html/panasonic_th37pwd7.html
    S.
  8. welshwizard
    welshwizard
    hi
    many thanks for that
    i think my pockets only go down to a TH37PE50, so ill
    do some research on the best prices around
    do JL generally pricematch anything ( ie online sites )
    cheers
  9. Ekko Star
    Ekko Star
    Mar 18, 2002
    6,616
    London
    +468
    No they dont and they will not match those Hispek prices either as they are web prices not instore prices.
  10. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    But JL will match any highstreet price your local shop@panasonic is a good place to start, JL give you a 5yr warranty so thats why alot of people push the price match you should also get a DVD recorder ES10 with the plasma which you could sell for £150+ if you didnt want it!!!!
