Quantcast
Which vape for CBD Oil
Ruffuz
Hi all,
any recommendation for cheap 510 thread compatible vape, purely for cbd oil.
I had CE3 kit, but it's was either fake or just crap.
Budget max £25 but prefer to spend as little as possible.
ctoom
the CCELL tank is the best choice now... but since every CBD brand has their own integrations, so you need test which one fit yours ....
