Which used Panasonic camera?
drunkenjoiner
Established Member
Hi Guys,
To save a few quid and hopefully get an half decent compact I am looking at the used market for the below camera's.
Straight forward question, which would you choose A or B.
A. Panasonic TZ10
B. Panasonic DMC-LX3.
Any input appreciated.
Many thanks,
DJ
nikonuser11
I'd choose the TZ10, think the specs are better than the LX3 afaik
mutamist
Established Member
Two quite different cameras. I've just recently had a LX5 and the image quality blows the TZ10 away in low light, but I wanted a camera with a better zoom so have gone back to a TZ10. All depends what you want to use it for. I also found the TZ10 a lot more pocketable than the LX5.
sleekyG
Established Member
Yep. If you want to go with the zoom, go with TZ10. Also, according to reviews TZ10 has higher user-reviews compare to the LX5. And I think it's a little cheaper. ;)
mutamist
Established Member
The LX5 is an update of the LX3, but the same type of camera. It's different to the TZ10 with it's bigger sensor and smaller zoom.
Spielberg, Shyamalan, Aronofsky, Chazelle, Eddie Murphy and Mel Gibson - all the latest movies
