I'm looking at hooking my TD-9 to a laptop so I can record my playing. For software I'm looking at Superior Drummer 2, probably matched with Reaper (but I'm open to suggestions).
The main thrust for this post though is in relation to connecting the TD-9 to the laptop. I can get a fairly simple USB to MIDI lead for between £20 and £30, or I can look at something like the M-Audio Fast Track which is pushing £100.
In terms of basic functionality and getting a good and reliable connection between the laptop and TD-9, is there any real difference between the two? Why would I use one over the other? The M-Audio site is 'suffering technical difficulties' so I can't get on there to check out all the details of the product.
The laptop does have a mini Firewire connection, but those devices are even more expensive.
All advice greatfully received.
