Which type or brand of Camcorder under £250
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by vileda, Oct 11, 2005.
  1. vileda
    vileda
    Oct 15, 2004
    401
    Sunderland, Tyne & Wear
    Hi all,
    I know this has probably been done to death but search isn't my friend at the moment and I only have 2 months to research this, so some pointers however basic will be appreciated.
    I'll have a budget of about £200-£250 (may be able to do £400 at a massive push), editing on a PC and burning to DVD.
    Only for family, light use, nothing professional but must be able to display a reasonable picture when output to a 852*480 plasma.
    Would prefer MiniDV With Firewire if doable.
    Many thanks
    Vileda
  2. laser
    laser
    Aug 1, 2004
    985
    Hartlepool
    +45
    If you are after a camcorder to display to a plasma you would be best looking for a true widescreen model.
    Canon make to good widscreen cams as does Sony and JVC. Check out their websites to see what is in your price range. All will have firewire and can transfer footage to a PC and all will do what you want. The Sony maybe a little out of your price range though unless you can stretch to £330 to £350 for a Sony HC39.
    Unfortunately Panasonic don't make a true widescreen camcorder at the moment.
