Which TV?
Discussion in 'General TV Discussions Forum' started by Simmering, Jul 4, 2005.
  1. Simmering
    Simmering
    Hi everyone
    I'm looking to replace my old Toshiba and am considering something like the Philips PW6518 or the DW6559. I was under the impression that these were basically the same tv with the latter one having the addition of the inbuilt digital 'Freeview' box (which I do not need because I have Sky). However, the reviews at Whatvideo for these models give a higher rating for the sound quality for the 6559 and I was wondering if anyone can throw some light on this?
    Although the picture quality is obviously important to me, the old hearing isn't quite as sharp as it used to be and so clarity of sound/voices is also a significant factor!
    It is naturally quite difficult to get an accurate impression of these factors in a crowded shop.
    Are the above 2 models decent choices or are there better options I should consider within a similar budget?
    I appreciate any help, advice and opinions anyone might have.
    Regards
    Simmering
