Which tv for a max of €2000
Discussion in 'What Is The Best TV For You?' started by Thelegend16, Jul 26, 2018.
  1. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Recommendations on purchasing a 65 inch tv
    For in around €2000
    Should I go for SAMSUNG?
    LG?
    SONY?
  2. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Each manufacturer makes good and bad. I'd recommend the highest range TV in your budget from the list here: Best HDR TVs - 2017 Edition
    Prices are different in different regions so it's hard to recommend certain models. Ideally you want to aim for the LG 2017 OLEDs which should be at their cheapest now as they clear out stock for the 2018 models. It will depend on local pricing how close these are to your budget though.
  3. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Thanks for the reply,
    I had a LG65SJ850V great TV, a green vertical line appeared on the tv sent it to Craigavon tv repairs, they got in touch with LG won't have the spare part till the end of September, so they gave me back a full refund of €1675.00
    Its decision again
  4. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    Does that mean you’re restricted to a certain retailer? North or South of the border?
  5. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Restricted to Harvey Norman south of the border.
    Just after been looking at
    Sony 65” XF90 €2699
    Sony 65” XF87 €1949
  6. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Tried to look on their website but their filter is broken so it's very hard. How much are the lg b7 or c7? What about the Panasonic oleds?
    The two models you mentioned are very overpriced for what they are. New models fetch a large premium. You're better off buying higher end from ranges from the year before.
  7. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
  8. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    HN zero 2017 models
    XF90 on line price is €2179
  9. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    I’ll check out the LG B7 and C7
    And Panasonic OLED when I get home cheers
  10. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    OLEDs will be 55”
  11. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Panasonic 55" OLED 4K PRO TV | TX55EZ952B
    €1839
    Panasonic 55" Ultra HD 4K Pro HDR OLED TV | TX55FZ802B
    €2499
    LG 55" OLED TV | OLED55B7V
    €1589
  12. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    You’ll find it difficult downsizing. I’d go for XF9005 @ 65”.
  13. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    I'd wait for the XF9005 to come down in price and also monitor the Q8DN and Q9FN for deals. I wouldn't spend over 2100 on it.
    Are the 65" OLEDs too expensive from 2017? They would represent better value than the 65XF9005.
    If the 55" B7 is only 1600 then the 65" version should be close to 2000.
  14. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    HN have no 65” OLEDs.
    While I agree re waiting - he has no tv; and it’s really only €400 he’s spending. It’d be difficult to wait.
  15. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Can you clarify op?
    First you said there are no 2017 OLEDs at Harvey Norman, yet there are only 55"?
    Second you said you receive a refund from Harvey Norman, does that mean you can buy elsewhere or not?
  16. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    I’ll check out the Lg B7 65 inch price
    Going to stick with a 65 inch I’ll struggle to downsize to a 55 inch, basically LG gave HN the value of the tv so I have to spend it in HN
  17. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    D23FBC53-8783-4DC0-B31C-3FBBDA134A93.jpeg That’s the issue I was having
  18. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    Man this situation sucks. Zep is right if limited to hn then the 65xf9005 is best value even if it is overpriced right now. Unless you look to spend less but it depends on the model and price.
    Their website is awful for finding different models.
  19. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Ok the latest update is LG has credit my Harvey Norman account, €1675 that’s how much I paid for the LG65SJ850V (has to be spent in HN)
    At moment I’m going for the Sony XK90 Which is costing €2179
    I might purchase a soundbar any recommendations?
    Thanks again lads.
  20. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    No idea with the soundbars but there is a soundbar section on this forum and reviews of soundbars too.
    You don't need wide viewing angles do you? That will be a major change with this TV compared to your lg.
  21. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Don’t need wide angle viewing, do you know if the Sony 65” XF90 been a success so far? Reading mixed reviews at the moment.
    Missing my LG65SJ850V do you know what the upgrade to the 65SJ850V is?
  22. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    XF90 has been getting good reviews - slight fly in the ointment is the Android OS but some users report no major issues with it.
    SK8xxx replaces your LG. I’d expect the Sony to be better, especially with black levels and contrast. But then again, if you liked the LG you’ll more than likely like it’s replacement.
  23. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    If you don't need the wide viewing angles you'll love the Sony's picture quality compared to your LG.
  24. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Think I’ve decided on the LG 65SK8100
    For a couple of reason..
    1. I liked my old LG65SJ850V
    2. Dolby Atmos
    3. Dolby Vision
    4. Nano Cell screen
  25. Dodgexander
    Dodgexander
    May 29, 2007
    15,236
    +4,411
    I have to say I don't agree with your decision for a number of reasons:
    First, you don't need wide viewing angles which means you could get better contrast, blacks and screen uniformity by going for a TV with a VA panel.
    Second, Dolby Atmos processing is useless if you do not have the means to reproduce it. Yes the LG may process dolby atmos but no TV is going to sound good, regardless of what sound it can process or not. If you want good sound you need to invest in a soundbar, integrated sound system or an AVR and Speakers.
    Third, Dolby Vision HDR is not a benefit to have on a TV that is going to be so bad with HDR to begin with. There are many boxes to tick for good HDR and the LG doesn't tick many of them.
    Last, Nano Cell is just LGs marketing for the TV having a wide colour gamut, its nothing different from other manufacturers, just with a different name. Samsung and Hisense call it Quantum Dot, Sony Triluminous, Panasonic Wide Colour Spectrum etc
  26. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    I’m backing tracking to the Sony XF90 €2179
    Has the Samsung NU8000 got good reviews?
    €1799
  27. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
    Mixed reviews. Sony worth the extra.
  28. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    The Sony is now €1999
    Might add a sound bar to it
  29. Thelegend16
    Thelegend16
    Jul 25, 2018
    38
    Dublin
    +13
    Ok finally got my Tv I went for the
    Sony 65” XF90
    If I could get some help what are the best settings for the Tv?
  30. zeppelino
    zeppelino
    Jan 24, 2018
    3,935
    134
    UK
    +1,209
