Which TV? 32ZP18P vs KV-32FQ75
Discussion in 'General TV Discussions Forum' started by kounkit, Feb 27, 2002.
  1. kounkit
    kounkit
    Feb 27, 2002
    44
    I'm a newbie looking for a 32" Widescreen TV.
    I have narrowed my search to the Toshiba 32ZP18P against the Sony KV-32FQ75.
    Main things I am looking for is image quality and decent sound. Mags currently rate the Tosh very highly, same goes for the Sony. But until today the sony was a whisker ahead but after reading the multiple threads here about the 'Sony Problem' I am unsure what to get now?
    I would appricate some feedback from people who own either of these sets or considered them both.
    One other thing on the toshiba do you need the front speaks to get decent sound or can you just have the speakers on the TV?
    Kit
  2. shaunthedude
    shaunthedude
    AVOID the sony FQ. I had one and it had about 4 faults. look at the other threads regarding sony. They are CRAP. I now have two panasonic tvs one of which is the PL36. Its a fantastic set. good luck in your choice
  3. Markster
    Markster
    Personally i wouldnt go for either but if you had to choose between the 2. It has to be the toshiba.
    The particular sony model you have mentioned has serious problems.
    HTH
  4. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    I have the 36" version of the Tosh, and love it :D
    As for the speakers, obviously you are going to get a much beter stereo image by having the front pair further apart, but if your room will not alow the sound from the set is fine, if a little mono.
