Which transmitter is stronger ?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by mortod, Jul 7, 2003.
  1. mortod
    mortod
    I have a choice of two transmitters, more or less in line. One is 10x the power, but is only 5x the distance away. Which one would give me the stronger signal ? (either 0.1kW at 12km, or 1.0kW at 57km).
    I know the obvious answer is to try it, but before I go to the effort of chaning my arial polarisation, thought it worth asking.
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,846
    Somewhere in South Yorkshire
    +5,078
    Too many factors - not just ERP and distance. Lie of the land; obstructions (trees, buildings). Plus - channels used vs. the type of aerial you have.
  3. mortod
    mortod
    Wide band aerial. Same direction so same lie of land. Interested in the theoretical answer assuming all other factors the same.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,128
    Manchester
    +715
    In theory , as power dissipates with an inverse square law, the 10 times higher power would not make up for the extra distance.
    Having said that , it very much depends also on obstacles between you and the transmitter antennae. You would need to do a path profile analysis to do a more accurate guess.
    So I would expect the nearer one to be better but you should suck it & see.
    Chris Muriel, Manchester.
