mattkhan
I'm starting down the road of building my own speakers & coming up soon is the need to build a test box so I can measure the drivers in their cabinet and start on the crossover. To do this, I need a box. Therefore I need some tools with which to build said box as I have none right now. Therefore the question is what should I buy?
I'm not a regular DIYer and I'm not expecting to become one however I don't want to buy cheap, crap & annoying tools. I'm happy to spend a bit more, if it makes a material difference, to get something that will last a long time and be a good tool to use.
I'm unsure whether to build the cabinets out of baltic birch plywood or MDF atm & here's the design if it makes a difference, cabinet is about about 18" high, 20" wide and 6" (+/-1) deep
Tools I know I will need;
- some sort of (jig?)saw
- a router
- clamps
there's bound to be other stuff but I figure a saw and a router are the key items
What would you recommend?
- a router
- clamps
