Which to buy? Pronto Pro or Marantz RC9200?
Discussion in 'Home Cinema Control & Remote Controls' started by Roughneck1, Apr 10, 2003.
  1. Roughneck1
    Roughneck1
    Guys which would you advise is the best?
    Don't wish to get too tecno with it...
  2. Loada
    Loada
    Mar 4, 2003
    591
    Guisborough, North Yorkshire
    +51
    The main advantage of the RC9200 over the PPro is the Marantz has a hard-button cursor underneath the screen (like a PDA). Also, the RC9200 comes with an RF extender, it's an optional extra with the PPro.
    Functionally, apart from a slightly bigger usable screen space on the RC9200, they are very similar. If you can afford it, I would go with the RC9200 just for the cursor.
  3. Roughneck1
    Roughneck1
    ok thanks... tell you the truth Pronto will win out i think as i like the idea of it turning on as soon as i pick it up which the 9200 does not do...
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    But Uncle Eric will soon be starting a power buy for the 9200 and as he put it
    so you just might save a few pounds if you can live with the 9200.
    Mark.
  5. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    MX700 would be much. much better!
