Which system?
Discussion in 'Home Cinema Buying & Building' started by spr33, Oct 22, 2003.
  1. spr33
    spr33
    Oct 22, 2003
    Basically, i've been looking for a decent system for up to £300.
    Requirments:
    - Plays: DVD / DVD-R / VCD / CD / CD-R / CD-RW / DVD-RW / SVCD / MP3
    - Decent sound (5.1)
    - Tuner?
    - Region Free
    The one i've been looking at is the Pioneer DCS-313. I've not been able to find a review for this exact model but have read the review of the discontinued DSC-303. The review said it was excellent and good value for money.
    I'm open to all views and suggestions.
  2. Wasabi
    Wasabi
    May 16, 2002
    1,188
    48
    SBC (Swedish Born Chinese)/lived in UK since 96, C
    +32
    spr33,
    You will find many positive owners here regarding 313. Excellent performance-to-pound ratio. It has everything you mentioned, good sound, picture + able to read jpegs and wma, DD, DTS, Dolby PL-II, RGB scart, S-video, 10-bit/54MHz video D/A converter and 96kHz/24-bit-compatible audio D/A converter, quite a few bass level/tone/mode controls and a OnScreenDisplay.
    The best deals at the moment are
    www.leconcepts.com/dvd_home.htm £280 with 3 dvds (choice between Monster's Inc CE, Chocolat SE, Godzilla SE, Ab Fab and Elvis Presley) and a free Gold plated OFC S-video to Scart contact
    www.techtronics.com/uk/shop/50-pioneer-dcs-313-multi-region-dvd-player.html? £260
    www.multizonedvd.com £267
    www.discountaudiovision.co.uk £265
    You can find 2 reviews at
    http://www.whatvideotv.com/
    http://www.whathomecinemamag.com/
    They gave 5/5 and 10/10
    Happy hunting and reading.
    Wasabi
  3. spr33
    spr33
    Oct 22, 2003
    Thanks mate. I'll have a good read up.
  4. bimmer
    bimmer
    I have Pioneer dcs-313 and it is great system. All I can say is go for it.
  5. spr33
    spr33
    Oct 22, 2003
    I did end up buying it and I must say i'm pleased with it. Have you tested +R / +RW DVD media on it. At dvdrhelp it says it's supported, but in the manual it doesn't list it as supported.
  6. bimmer
    bimmer
    No I didn't test +R / +RW DVD media on it.
  7. spr33
    spr33
    Oct 22, 2003
    bimmer: Do you have stands for the rear speakers? If so, which one's do you have. Are the 'connectors' 'universal' or are they specific for brand / model?
  8. bimmer
    bimmer
    No, I don't have stands, because i don't need them, i have great spots for them in my room so they are perfectly placed.
