Which svs?
Discussion in 'Subwoofers' started by newbie265, Sep 10, 2004.
  1. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    My room is 12 by 30 listening area 12 by 14.As I said in the speakers thread am demoing monitor audio silver s6's and s1's for rears next week at sevenoaks.If I like them will be buying in the next couple of weeks so need to get a move on for my svs .I was recommended the pc plus 20-39 but i heaqr there is a new smaller one coming out.Just wondered if that would be better for my rrom and more musical.I probably won't use the sub for cd replay but i play a lot of music dvds ,hence the need for a musical sub.many thanks
  2. recruit
    recruit
    I don't think you can wrong with any SVS sub as they are all musical, but email them with your requirements and i'm sure they will help you out ;)
    www.svsubwoofers.com
    John :)
  3. avanzato
    avanzato
    Jan 21, 2003
    1,962
    Norfolk
    +80
    How are you wiring up the sub?
    The new SVS comes with limited connectors, ie 1 phono, AFAICT.
  4. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    I've no idea I am new to this,but I am going to get Sevenoaks to install my system so was going to ask them to do it.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    Most of us don't need any more than a single phono cable to connect up our subs. Certainly you will get the best out of both film and music DVD with justy this connection.
    A minority of people like to connect up to the speaker terminals on the amp in addition to the low level connection but in most cases it isn't necessary.
    I would be interested to hear the reaction of Sevenoaks if they connect everything up for you as I don't suppose many (if any) will have heard an SVS in action
  6. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    I will certainly let you know Ian,do you think the 20-39 pc plus is teh way to go for my room?
  7. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The 20-39 PC plus is more than adequate for your room unless you are constantly listening at reference levels
  8. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
    Stop confusing the issue!!!! :D
    Newbie265 is getting rear speakers. :)
    He wouldn't be doing this if he was getting a 2 channel stereo system. :cool:
    So he must be getting a multichannel AV system. :smashin:
    So the 10" PB10-ISD will work just fine in his system. :thumbsup:
    If it's any good. :devil:
    Nimby
  9. newbie265
    newbie265
    May 21, 2003
    493
    Rochester, Kent
    +7
    Ok I'm about to join teh svs club as I have ordered the 20-39 pc plus today on Ian's recommendation>i'm sure I won't be disapointed even though I have never heard it.Cost was $825 does anyone know what the total cost will be?
  10. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    It should cost between £650 and £680 depending on where you live. It seems that some airports are cheaper than others and some people live miles away from the airport
  11. Stellavision
    Stellavision
    Apr 7, 2003
    2,375
    Southsea, UK
    +101
    I had an SVS 25-31 PCi in my previous home which was 13' X 14' and it filled my room with good bass with ease.
