Which Surrounds to Match S85's???
Discussion in 'Home Cinema Speakers' started by SpiderManPants, Mar 5, 2003.
  1. SpiderManPants
    SpiderManPants
    Evening All,
    I am currently running 3 x M&K S85's at the front with a 3801 as a processor and the mighty Rotel RMB-1075 on amplification duty.
    My question to you all is...
    Which speakers shall I get for my rear channels?
    I'm only thinking 5.1 at the minute, but I may add the back channels at a later stage. ;)
    My thoughts so far are as follows:
    M&K S85's
    M&K SS-150 MK II (Pricey and only possible if a miracle occurs soon! :eek: )
    M&K Surround-550 MK II
    M&K K-5's (In white :smashin: )
    Definitive Technology BP1X (In white) - Considering because I've seen a cheap 2nd hand pair, but not sure about integration with the M&K's! :confused:
    I would appreciate any comments/suggestions from you all. :smashin:
    I especially would like to hear from anyone who has used any of the above with the S85's. :)
    Thanks in advance
    Spidey
  2. chips
    chips
    Dec 3, 2001
    2,403
    2NM S EGTF
    +24
    SS-150s sound superb with the S85s :D. I would think the next best thing would be some more S85s;)
    Eric's the expert on M&K though.
  3. nathan_silly
    nathan_silly
    What abaat the SURROUND-55 MK II?
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The tripole S55 are well worth a listen, they should be a great match.
  5. chips
    chips
    Dec 3, 2001
    2,403
    2NM S EGTF
    +24
