Quantcast
Question Which surround system/soundbar?
I have just purchased a new TX-55GZ950B and realized that the leads on my previous surround system (SC-BT200 Blu-ray home theatre sound system, see picture) cannot connect either to the TV or to the UB820 Smart 4K Ultra HD Blu-ray & DVD Player I also just bought (second picture). Any idea whether there is a solution to this with adapters etc, or is there no other solution but to buy a new surround system/soundbar? For the latter I have identified the SC-HTB900EBK 3.1 Wireless Sound Bar with Dolby Atmos as something I like, but perhaps there is a more economic alternative? To be fair, I would be more than happy to stay with the surround system I have at the moment, if I could find a workaround the connector/plug issue. But if I go for a new purchase, I just need to make sure it does my new TV and blu ray player justice (they both support dolby atmos, 4k etc ). Many thanks.
JayCee
Your Surround system according to it's specs has an optical input.
Your TV has an optical out, connect the two with an optical cable and you're good to go.
