Which surround speakers
Daz1969
I'm in the process of converting a back bedroom into a dedicated cinema. I'll be using a pair of B&W CM8's with a CMC2 centre, CCM362 ceiling speakers for atmos but can't decide what to use for rears.
I was considering CM1's but think this may be overkill for surrounds, so with that in mind does anyone have any suggestions??? I have also considered the M-1 surrounds, would these be a good match?? Ideally i'd like to keep it all B&W but due to room shape cannot realistically use dipoles.
PSM1
I would personally go for the CM1s so that they are all matching. I have some pretty expensive speakers for the surrounds but they are the same make/model as the fronts which is why I went for them.
Daz1969
I am considering them but also will need to be putting in a sofa bed (to keep swmbo happy) and as such the M1 on a wall mount may be a better option, just need to see if they will be a good match. The room will be used for music too but the CM8's will be taking on that role as well.
Panasonic HZ2000 4K OLED TV Review | The best OLED for movie viewing in 2020
