Which SUbwoofer??.
Discussion in 'Subwoofers' started by andy76, Mar 23, 2002.
  1. andy76
    andy76
    I am looking for a subwoofer with a maximum budget of £500.
    What recommendations would you give?
    At the moment it will be mainly used for music and would be used in a stereo only system - how do you connect it without a dedicated sub out?
    I do watch DVDs etc too though so something that is good for movies too would help and I do intend at some stage to change over to DD or similar - space allowing!
    Andrew
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    For a £500 budget I recommend either the B&W ASW1000 or the newer ASW650 (? the better of the 600 series subs).
    They are both very good.
    Connecting without a sub preout you have two options.
    If you amp has stereo pre-outs then you can use these to the matching inputs on the sub, or you can run speaker level. This can either involve daisy chaining the sub into the speaker runs or running the sub from a B speaker output on your amp.
    Have fun!
  3. robh2002
    robh2002
    Mar 7, 2002
    374
    28
    Sheffield
    +31
    Easy. If you have space and if it's only for movies, go for the Servo 15 at Richer Sounds - you can't go wrong.
    Rob.
  4. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,950
    and if you read his/her question, its going to be used mainly for music.
  5. robh2002
    robh2002
    Mar 7, 2002
    374
    28
    Sheffield
    +31
    Whoops - still half a sleep...
  6. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,950
    in that case, we'll let you off :)
