which subwoofer?
Discussion in 'Subwoofers' started by todinks, Nov 8, 2001.
  1. todinks
    todinks
    i'm upgrading my system from prologic and want a kick-ass sub specifically for home theater.
    what should i be looking at?
    B&W ASW-1000/B&W ASW-2500 - how are they in comparison?
    how about REL? whcih model would be perfect for a room size of 260 sq.ft.?
    advice anyone?
  2. pc
    pc
    The M&K V125 is great. Check out the review in this months hcc.
  3. Lowrider
    Lowrider
    The REL Strata III sounds very loud in my 340 ft room...
  4. pc
    pc
    surely we're all after something more than just 'loud'. We want dynamics, speed, control, depth, seamless integration AND loud! The M&K's do this fantastically, especially the larger push/pull models.
  5. Lowrider
    Lowrider
    Paul,
    I assume that when someone asks if a sub would fit a certain size room he wants to know if it will be powerful (loud) enough for that room...
    I don´t think anyone needs to be told how good the REL speakers dynamics, speed, control, depth, seamless integration are...
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The MK V125 gets my vote.
    Failing that the MX350.
  7. pc
    pc
    MX350. mmmmm nice
  8. todinks
    todinks
    nobody likes B&W subs???
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    The B&W ASW 2500 is a good sub, but if you've got the room you should go for the V125.
  10. Guest
    I'd have to say REL but then there is more than a little Bias you see we're both welsh.
    No they're Great Subs
    also Try richer sounds £150-200 will get you a Nice REL looking sub.
    But what I'd love to do is get a kit from
    http://www.iplacoustics.co.uk/ipl_acoustics_kits_for_hi.htm
    And build my own Just think of the braging value "ho yes I built that little number myself and does'nt it sound great."
  11. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,771
    7
    2
    167
    Birmingham, UK
    +10,676
    Ok, so your best options so far would be to audition a REL - Q150, Q200 Storm or Strata, the B&W ASW 2500 and the M&K V125 or MX350.
    There is a subwoofer buying guide I wrote somewhere - either on HCC or at the REL site. Basically go for depth rather than mid-bass boom - even though in an audition - to the uninitiated - the latter may 'sound' more impressive than the former.
  12. Peter
    Peter
    I auditioned the REL Q400 and the Q200, and decided that the Q200 was enough for my needs, intending to buy a second one if it proved necessary. I've never felt the need to. Dynamics, speed, punch and sheer b*lls are excellent. It's great with hi-fi, too - nice and subtle.
    I initially considered the B&W's as I was buying their speakers, but the REL was so much smaller (wife factor) and seemed better value.
  13. Laingy
    Laingy
    has anyone compared the rel 200 to the 201?
