which subwoofer
Discussion in 'AV Receivers & Amplifiers' started by arrif, Jun 6, 2001.
  1. arrif
    arrif
    i have recently purchased a denon avc 10se my problem is i am using a a pair of b&W dm604's as my front which is a very strong front bass heavy speaker i am very new to the dolby digital scene and this is my first av amp i have a dilema as to what subwoofer to get so for those of you who are out there that know your subs can you please advise my budget is about 600 pounds
  2. bug
    bug
    Go for a paradigm servo 15 from richer sounds, Were £800 now £500.
    Checkout the reviews it's a real bargain. ;)
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    normally i wouldnt recommend the paradigm.....but you really do need something of its size and power to match your front pair!
  4. arrif
    arrif
    yes i have heard of this sub at it has good ratings and i was considering it also on my shortlist was the b&w 2000 and the rel q200e what do you think of these two subs thanks for your reply
  5. Guest
    I was also looking at the B&W 2000 but they have stopped making it now, so unless you can find a dealer that has one in stock or are buying second hand, you will have problems getting one.
    I ended up getting the new ASW2500 but its a bit out of the price range you said, being £895.
    James.
