Which subwoofer cable do I need?
Discussion in 'Cables & Switches' started by townfan, Jun 1, 2004.
  1. townfan
    townfan
    Jun 7, 2003
    759
    Devon
    +35
    I have a Yamaha HTR-5640 amp along with Mission M70 surround speaker package, I need a subwoofer cable to connect them together but which one do I need? The sub has 2 line inputs but most sub cables are single, do I need a cable with a "Y" connector on one end or will a single one be OK and which make is best suited? My budget is £25-30.
    Can anybody offer any advice?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    One cable will do and for the very best quality one of Mark Grant's cables available in the Powerbuy forum here will be just the ticket and even if you upgrade your whole system several times that will be the item that never needs upgrading.
    Although you mentioned your budget you didn't mention the length required and this cable should be "around" your budget unless you are looking for a very long length
  3. Cmoth
    Cmoth
    Apr 21, 2004
    1,095
    38
    Hertfordshire
    +19
    Yes one cable is sufficient.
    [edited by Ian J. Please use the hardware trading forum ]
  4. Zone
    Zone
    Jun 24, 2001
    6,526
    Barnsley
    +2,114
    Why not pop down to Maplins get yourself some double screened coax, RG59 etc a couple of screened phono plugs and have a go at diy; £3/4 a meter all in.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Could you confine any and all trading to the hardware classified forum please as that is not the purpose of this forum.
