Which Sub Woofer for Technics
Discussion in 'Subwoofers' started by geekbeek, Jan 5, 2007.
  1. geekbeek
    geekbeek
    I have a Technics SA-EX510 AV Receiver. There is a provision for a sub in the amp itself. what i would like to know from all ya respected folks is that which sub should i connect, a passive one or an active one & which model/brand would suit it the best. :)
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    If it is a standard phono out connection you would connect and Active Sub to it. It should be in your instructions.
  3. geekbeek
    geekbeek
    I lost the instructions paper. the amp is pretty old now. it is a phono out. which sub with what rating do you think would suit this best ? :)
  4. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
    You would really need to match to your current speakers, what make and model are they? How much is your budget?
  5. Andy98765
    Andy98765
    Feb 15, 2006
    10,472
    2
    +1,365
  6. geekbeek
    geekbeek
    i have yamaha nsa-1236 floor standing speakers for the front & VAV Audio bookshelf for the rear
  7. geekbeek
    geekbeek
    *****bump*****
    That panasonic site does not open
  8. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Does this help.
    Russell
  9. Nimby
    Nimby
    Jan 27, 2004
    9,206
    The Danish Bacon Factory
    +671
    Nope. :D
    "Timeout accessing resource". :confused:
  10. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    :mad:
    geekbeek, PM me your email address and I'll send you the PDF, if you want it.
    Russell
