Which sub to go with Mission 753's
Discussion in 'Subwoofers' started by Jpfahy, Apr 9, 2003.
  1. Jpfahy
    Jpfahy
    I am looking to get a sub (at last!) to go with a set of Mission speakers I have on my home cinema setup (not a big music fan BTW).
    753's Front
    75c Centre
    771 Rears
    All set up in a small lounge (4x4.5M, Tiled floor)
    I am told I might need to spend a fair bit to get something that goes "sonically" (whatever this entails :confused: ) with the "good quality bass" that the 753's kick out. I'm on a budget of £300'ish.
    I know of the Pro 50 & Quake, but am wondering if these will have enough grunt to compliment the 753's.
    But then saying that, the volume rarely gets cranked that high in my semi-detached (poor old dear next door etc etc)
    However, on the rare occasion it does get turned up I'd like something that sounds impressive.
    Can you knowledgeable dudes point me in the right direction here, please? It would be most appreciated
  2. Drew Peacock
    Drew Peacock
    There is a thread running concurrently where someone complains that the MJ Acoustics Pro 50 doesn't provide enough grunt and muscle and a couple more singing the praises of the Velodyne CHT10 in your price bracket.
  3. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I have almost the same set-up (753,75C,751)and have found my CHT-15 works wonders. Though a little over your 300pound budget i'd certainly recommend you listen to its baby bro, the CHT-10.
  4. stranger
    stranger
    don't skimp on a sub for your setup, try for something like a servo-15 or velodyne cht15 if you have the room. if you're really tied to your budget-go second hand or save a bit more-you wont regret it it, a poor sub now will just be throwing money away without doing justice to you present setup.
  5. Jpfahy
    Jpfahy
    Thanks for the quick response there guys :D
    Somehow I knew things would edge towards the Velodyne solution :p
    If I were to go for the CHT-10 (anything more expensive is beyond me) would it really be considered a compromise?
  6. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    No - read Juboy's review of the CHT-10 where he compared it to the more expensive REL Q150
  7. stranger
    stranger
    a cht-10 would be a good compromise and would hold its value should you decide to upgrade-also near your budget is the paradigm 2200 at richer sounds.
