Which sub is better than the SVS PB13 Ultra?
Discussion in 'Subwoofers' started by saguk1234, Jun 22, 2015.
  1. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Can anyone help here?
    The sub needs to be sealed. I don't want multiple subs.
  2. mattkhan
    mattkhan
    Nov 14, 2005
    9,561
    Beckenham
    +4,527
    no one can really help because you haven't given a definition of good nor listed any constraints (everyone has constraints)
  3. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Pb13 is good but I want better. I want roughly the same depth but better control. Constraints will be price. Being £5000.
  4. pws
    pws
    Jan 27, 2004
    2,211
    Swansea
    +194
    1 sub or more?
    I went to 2 DIY 15" subs that walks all over the PC13U I had
  5. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Just one. And no DIY.
  6. mattkhan
    mattkhan
    Nov 14, 2005
    9,561
    Beckenham
    +4,527
    I thought the constraint was price but this implies price and, presumably, space
    what about room size & seating area? what mains do you have/want to integrate with? is it music and HT or just HT?
  7. pws
    pws
    Jan 27, 2004
    2,211
    Swansea
    +194
    so....two more constraints :)
    I cant help sorry as my experience passed a PC13U is DIY sorry.
  8. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    I have monitor audio platinums. Space is not an issue as I have the pb13 and its massive. The room size is 5 x 4m and 3m tall. And I am 95% home cinema.
  9. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    I guess these
    15" Rythmik/seaton/HSU
    JTR Orbit Shifter LFU
    Powersound 15"/18"
  10. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Another constraint is that the sub shouldnt need to be imported in.
  11. mattkhan
    mattkhan
    Nov 14, 2005
    9,561
    Beckenham
    +4,527
    should or shouldn't? I assume you mean shouldn't as it would be odd if you said "imports only" :)
  12. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    If you mean UK distributors, Power Sound are. For some of the others need to import yourself (check voltage)
  13. mattkhan
    mattkhan
    Nov 14, 2005
    9,561
    Beckenham
    +4,527
    if you really want to maintain the low end output of the SVS then you are going to need a lot of sealed sub, for example check the list here -> Data-Bass and keep going til you see a single sealed sub (and also note how high up the SVS is)
    Your budget helps though. Your choice probably boils down to something like
    a bigger JLs (fathom v2 probably? I don't know their range)
    PSA T-18
    Paradigm Sub1 (or Sub25 if one can be found)
    a pair of KK 12012
    You could also look at something like PRO AUDIO TECHNOLOGY - LFC-18sm but I have no idea how much they are, @sammy the squid can probably give you a clue.
  14. sammy the squid
    sammy the squid
    Jul 5, 2009
    9,023
    Lancs
    +3,645
    I think a single LFC 18sm retails near £5k. However, that doesn't include the Amps. Pro Audio recommend utilising the subs in pairs and as such, the Amps for these come in a 2 channel configuration. I'm pretty sure the amp would cost you more than a single sub.
    I might be relisting my Paradigm Sub2 again shortly in the classifieds. The retail price is now £11-£12k. Has the looks and the performance to beat the Pb13 Ultra into a hat. It obviously comes at a price.
    What the Ultra 13 has is depth. But that's it as far as I'm concerned. For the right money, it can be beaten with subs available here, but it will come at a cost and in most cases require multiples (not where the Sub2 is concerned though :)).
    Edit: @mattkhan, the Pro Audios are ported designs, bar the LFC 14sm which is sealed.
  15. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Sub 2 would be too expensive.
    I don't mind sacrificing a little depth if the other bits are better.
  16. sammy the squid
    sammy the squid
    Jul 5, 2009
    9,023
    Lancs
    +3,645
    I think mine was advertised at £6k previously and that's what I'd be looking for again. If you're looking for a single box solution that is not a Diy effort or imported..then you're pretty much running out of options...certainly for beating the depth of the 13 ultra and maintaining the top end.
  17. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
  18. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Imported meaning import tax. Also has to run on UK without step down.
    The problem with the seaton subs is the better ones are 110v.
  19. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
  20. mattkhan
    mattkhan
    Nov 14, 2005
    9,561
    Beckenham
    +4,527
    no that's not true, they use speakerpower amps which have a 240V version. @AidenL just imported a pair in fact.
  21. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    I will research seaton again. How about a power sound s3000i?
  22. indus
    indus
    Oct 1, 2006
    5,986
    +1,314
    May I ask why it has to be sealed?
    I know some will say that it's not really a sealed sub if you need to use bungs but have you considered the xtz 3 x12?
    My HT is exactly the same size as yours (funnily enough I have platinums as well but now only for stereo in another room).
    My 3x12 sounds wonderful now that I've got the antimode and is streets ahead in all regards compared to my previous SVS PCU13.
    Perhaps worth considering? It would save you a heap of money that you could spend on other kit!
  23. mojogoes
    mojogoes
    Remembered (1961-2016)
    Oct 12, 2007
    10,469
    Faraneverland
    +1,984
    PB13 Ultra and PC13 ultra are two different beasts..................Well one of them is?
  24. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    I just want one sealed sub. Ported subs are too boomy for me.
  25. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Then
    SVS SB2000 x 2
    SVS SB Ultra 13
    BK XLS 400 x 2
    Power Sound S1500
    Power Sound S3000
    JL Audio series.
    M&K DXD808/12012
  26. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    No x 2!!!
  27. saguk1234
    saguk1234
    Nov 7, 2007
    4,936
    London
    +231
    Sub 1 and sub 25. My acoustics 800 mark 2
  28. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
    Since you only want one, then you need to get a better one. A single SB2000 I don't think will be sufficient, for movies in medium/large room. Go for SBU13 then
    Also Power Sound T18.
  29. stephenbarnes
    stephenbarnes
    Sep 18, 2013
    4,872
    +846
  30. sea surfer
    sea surfer
    Jan 6, 2003
    4,957
    Glasgow
    +946
    Push the boat out! and go for the Sub 1 and be done with it :D sub 1.jpg
    It :beer: all your boxes :smashin:
    You only live once :lesson:
